I bought my first Honda about 3 months ago. A 91 Honda accord with some issues. The guy didn't take care of it. Anyway the old f22 blew. I found a wrecked 92 accord with a late 90,s f23a ulev v-tec. Thanks to this sight Ive been learning allot. I did the swap and decided to leave my automatic trans in it. The v-tec was hooked to a toggle switch on the wrecked car. I bought a shift light tach and used the light wire to engage my v-tec in at 4k. I know this sounds primitive but remember I am the Honda noob. I welded a new exhaust in with no cat or resignator. It has a short air intake. Just the aftermarket muffler. I did away with the trouble lights and went with aftermarket gauges. Here comes the questions. When I really get on it, it starts to spit up at 4500 rpms. Like its not getting enough fuel. When its been sitting for a long time it takes awhile to start. It runs and idles smooth. If this helps I kept the f22 intake on it.
F23a swap questions
That may be a large factor.
Since the F23A1 is an OBD2 motor, it's a pain to use the proper ECU. Look for a P0A ECU from a 94-95 Accord EX. It's made for the F22B1, which is a 2.2L VTEC motor... but it will run your motor MUCH better than the PT3 or PT6 that you're using now! not to mention, you'll be able to wire up VTEC properly, rather than having it hooked to an RPM switch (which, I must say, is innovative to say the least!)
Also, using the injectors from the F22B1 might be a good idea as well... as I'm sure you're using the OBD1 F22A injectors.
