h23 block / h22 head timing belt q??
    So I picked up a 93 accord with a h23a1 block and h22 head with vtech and i blew the timing belt on it. I found one at auto zone but seems too tight and dont know what kinda car the swap came out of so what belt am i looking for h22 or h23 and how many teeth should it have? thanks!
    you found one at autozone? like on the ground or in the garbage can?
    i would suggest a h22 one since the h22 block is simiiliar to the h23.
    I <3 G60.
      lol yes it was just sitting there on the ground meaning they had them in stock some vtech some not
        for shore its a H22 timeing belt if they did the swap correctly you should just buy the h22 belt and be all set i use to have this set up in my car previously
          yeah the h22 belt has more "teeth" on it than a 23 if it helps you you need the h22 water pump to
            you "blew" the timing belt on it? Do you know if you "blew" anything else up? or bent a couple valves?
