im getting ready to change my tube seals to fix my oil leak after reading the tutorial and reading the valve adjustment tutorial (plan on doing that too) i have a few questions
first of all whats the best way to remove the camshaft i keep seeing mixed answer on methods of taking off the timing belt and its the only part im nervous about
second how do i adjust the valve? loosong the outter nut and then which way do i turn the one on the inside? can i use conventional wrench?
and third i read that not all the bolts on lifter assembly come out which are the only ones i need to remove?
thanks in advance
thanks in advance
