Need help removing bumper lamps
    Well, I was removing the bumper lamps on my accord when I found out that the screw is stripped and cannot be removed. Same for the other side. I heard about the screw extractor kit and got one until I notice that the extractor and the drill bit are too short to reach the stripped screw. Any advise on what to do? Thanks in advance.
    Just take a drill and start with a bit a third of the size of the screw...and drill and 1/8" into the screw. Then use Phillips head to try to spin it out enough to grip the head with a set of pliers. or, you could try to find a longer extractor.
    A nice car is a dime a dozen. It's the amount of respect you give your car that makes it a GREAT car...and it shows.
      Try just popping the lights out. The screws stay with the housing, so it's possible that they aren't even screwed in. Mine have felt stripped out, but weren't.
      cb773 - way to whore it up!
        yeah i think they do just pop out, if not press on them from the back while unscrewing it
          will give your ideas a try. I will inform ya if i cant get to it.
            got them removed. thanks to those who helped. I really appreciated it.
              just need to get the screw on the lamps to line up straight with the clip so it could be screwed in.
                put some rust eater on it like WD40, then take a philips screw driver and a hammer.
                Put the screw driver on the screw and hammer gently on it by turning the screw driver in each direction.
                It will allow the fluid to penetrate and ungrip it.
                Then try to unscrew it.
                If this doesn't work try by drilling thru the head of the screw.
                CB8-Tuner
