Does Cb7 Stock Intake Fit On F23a1 Monifold??
    i have a f23a1 motor with manifold and i was wondering if the stock cb7 intake fit the manifold
    Ummmm, I know this isn't helpful to you but why would you want to do that?
      i have a f22a in my car right now.. i bought a f23a1 with the manifold intake and i was wondering if the intake of my f22 fits the f23 manifold intake
      im not a mechanic i really don't know much about swaps im just learning
        Stock of aftermarket (short ram/cold air)?
        The tubing will fit fine on the manifold...
        Are you swapping the F23 into your CB? If so, and you're using the stock intake box system, you would have to use your CB airbox/tube because it's built for the CB's engine bay.
        On the other hand, if you were trying to retrofit the airbox system into your CB from a 6th gen, it would most likely be a bit more difficult..
        Now, the intake manifolds themselves, on the other hand - they are not interchangeable between motors.
        My pictures/photos will return soon...
          Yeah see I thought you meant the intake manifold.
