Put Fart Can on and Car Running Crappy
    Hey guy's, like the title says I put a fart can on my cb and I went out for a drive to hear it and after my car got all warmed up (normal temp) it started to act like it was missing and shit. I have no Idea what it could be because the muffler is wide open (I can see right through it).
    Could it coincidentally be that my cat got plugged up, and now after I put it (fart can) on it's showing signs?
    It runs great until she warms up, do you guy's have any suggestions?
    Thanks.
    Click picture for MRT
    Sparkin CB7
    I don't know what "quiescently" means, but are the engine RPMs bouncing up and down once it is warm?
    "The fault-finder will find faults even in paradise. Love your life, poor as it is. You may perhaps have some pleasant, thrilling, glorious hours, even in a poorhouse."-Henry David Thoreau
      Lol I meant like a coincidence but I didn't know how to spell it.
      Nope the RPM's stay right at 700.
      Sparkin CB7
        I think he means coincidently...
        Either way, I would have to say that it's just a coincidence and there is something else wrong. What? Hard to say. Did you have to or happen to remove anything else when you were installing the fart can?
        Click Image for CB7Tuner.com Beanies, Decals, & Keychains!
          you put it on or someone welded it?
          reset the ecu if the battery negative cable wasnt unplugged.
          I <3 G60.
            my OEM muffler rusted off so I just decided to clamp on my fart can I had. I was driving without a muffler for about a week with no problems and all of the sudden this happened after I put the fart can on.
            Sparkin CB7
              so was it put on or welded on?
              I <3 G60.
                Just clamped on. Not welded.
                Edit: One of these
                Sparkin CB7
                  Do you guy's think it might be the cat?
                  Sparkin CB7
                    I would reset the ECU, like wed3k said to do.
                    -mak
                    Bought From: MadSpleen85, jimy, CB7_ACCORD (kouzie), Chrisfrom1986
                    Sold To: vinbon63, chessboxer, darkfusion42, LowNknoxville, bowzil, 1993hAccord, mcdizzle, 93accordfreak, lilb_1979, rocketman_471, Bad_dude
                    Traded With: cb95spd, chessboxer, sohc em
                    [ Completed | Pending ]
                      Really? Even though I didn't weld anything, I just clamped a new muffler on.
                      Sparkin CB7
                        Why not? Even if you didn't unhook the battery, it can't hurt. Start with the small things you can try to fix for free and work your way up, that's my motto
                          Ok thanks for the help.
                          Sparkin CB7
                            could be a bad o2 sensor. If you go WOT does it act right or still sputter?
                            most likely not a result of the muffler IF the muffler alone is all you touched.
                            ____
                              If I go WOT it does still sputter but if I stay at a constant pace (2K RPM's) it's fine.
                              Sparkin CB7
