Pc680 Battery Question?
    If i buy a PC680 do i need a new bracket to hold this Battery?
    You mean a battery tie down? All batteries need one, or else it will flop around when you take corners.
    Past 1990 Accord EX Sedan
    Past 1990 Accord LX Sedan
    Past 1991 Accord LX Sedan
    Past 1993 Accord LX Wagon
    Current 1991 Accord EX Wagon
      my optima was fine without a tie down.
        Agree'd so is my group 26...but its massive compared to the stock one..
        Dragnskull <3 Tacit says:
        *i dont understand how people can even work on these piecse of shit
        *theyre the emachines of cars
        Leefhead says:
        *that sums up GM in a single sentence
          Honestly if you are going to go with a smaller battery like the PC680, relocate it... that's what I did.
          I built a box for it and mounted it lower down, basically right under where the stock battery tray is. Make the engine bay much cleaner.
          ^ Batter holder
          ^ Battery all nice and snug in it's new location
          ^Cleaner engine bay (still needs some work)
          Click Image for CB7Tuner.com Beanies, Decals, & Keychains!
            ^ Batter holder
            THAT IS COOL AS FUCK!!!! i want one.how much was the battry
            my new turbo build
              Battery ran me $130 shipped.
                looks like a charger is hooked up. does it hold charge for long?
                my new turbo build
                  I've had it sit for two and a half weeks and still start without issue. When I took the pictures I had let the car sit a little longer then four weeks (working on my building), so I tossed their battery tender on it to keep it nice and charged. Something people should think about since this is classified as a racing battery.
                    were u get the battry from? how did u make the box for it.
                    my new turbo build
                      I bought it from Portable Power Systems. However you can get it off Amazon for $127 shipped.
                      What I did to make the box was I took the metal jacket that you can get with the battery (part number should end with MJ), attached two 1/8" thick x 2" wide aluminum bar to the metal jacket and that was it.
                      The thing that took the longest was getting everything lined up correctly for bolting it down because I wanted to use factory bolt locations instead of drilling and taping new holes.
                        ^Nice work on that, I admire the extra work using factory bolt holes! My 680 is getting pretty old, but it has always been fussy during the winter, I'm going w/ a big battery for the winter this year. I'm pretty much @ the point of needing a new 680 anyways, I bought it used from PrimoCB7 roughly 3.5 yrs ago!
                          Thanks, I really like using factory bolt holes whenever possible. Takes a lot of work sometimes but its totally worth it.
                          But yeah I've noticed on really cold days it can be a bit hard to start so a winter battery wouldn't be a bad idea at all for anyone thinking about doing this.
                          I'm just amazed at how much abuse you can give this battery and it STILL charge back up to 100%. Might bump up to a larger Odyssey battery later down the road for more CCAs and a higher reserve... but for right now this 680 does a fantastic job!
