f22a6 doner motor
    f22a6 doner motor
    i have come across an f22a6 with 360000km on it. i put it on an engine stand in my shop today and took the exhaust manifold off of it for my a1..what other parts could i take to gain a bit of power that just bolt on..i don't really want to get into internals although i will be taking the camshaft out.
    92 Accord EX - SOLD
    PSN: REDxMAN-_-
    MR===>http://www.cb7tuner.com/vbb/showthread.php?t=146478
    You want the intake as well and the ecu if it came with the motor
    Click it.... You know you wanna
    Bought from:Joshy,H22WAGON93, nho93accord,90accordLXGUY,phantomCB7,Tommi
      The cam, ecu, and intake manifold.
        windage tray and oil cooler
        1992 Accord Wagon (RETIRED)
          whats a windage tray?
          92 Accord EX - SOLD
          PSN: REDxMAN-_-
            It's a tray that goes in between your oil pan and crankshaft to keep your engine from starving for oil at higher rpms. It helps keep the oil at the pickup.
              hmmm do the a1/a4 have that?
                No, only the a6, and you already had a very similar thread.
                http://www.cb7tuner.com/vbb/showthre...88#post2267088
                  You want the A6 oil pickup too, as it is different than A1/A4 and needs to mate with respective windage tray.
                  Take A6 water pipe too, as it has extra nipple for oil cooler coolant hoses. Technically, the A6 block has a coolant port to top-right of oil filter housing area that is for oil cooler as well.
