crunching sound when turning
    okay so i just replaced all of my suspension and sway bar end links hoping that would maybe get rid of this weird crunching sound my car makes when turning (but it didn't) it's made this sound since my brother has had it over 2 years ago. doesn't seem to be hurting anything but it annoys me to no end.
    any idea on what to check? the axles/joints are newish so i'm pretty positive it's not those unless they put them on incorrectly. maybe wheel bearings slowly taking a crap?
    90 ACCORD EX..<-- MR thread
    if it happens when you turn its most likely your cv axle/axles you should take off your front tires and check em make sure you did them right
      yeah sounds like it could be a broken c.v axle
      I know....I'm gunna lower it
        define broken? they spin like they should and have done this since they were replaced
          yea they spin fine when pointing straight out... but how are they if you have em bent like your turning? if you cant spin it then.. there no good.. or if it feels like something is broken.. it probably is.
            Most of the time the boot that voers the cv axle will have a tear in it letting the grease that WAS in there out, and letting water and dirt in. The boot doesn't have to be torn though for it to be messed up. I'm not saying that's what it is. But if nothing else you could check out the boots on your axles just to be sure if you haven't already. I've never heard of a crunching sound when someone was turning. All of the axles i've had break made more of a knocking noise lol.
              the boots still look brand new, no tears whatsoever. i just installed my front struts the other day and inspected them pretty well. if i can remember right they turned fine when i had the wheels turned and off the ground but who knows. i guess i can put it on my list of shit to do haha
              what replacement axles would you guys suggest?
                Have you put it up on jack stands and turned the wheels both ways to see if you could come up with anything? I've gotten axles from Auto Zone, Napa, and Advanced and never had a problem with any of the three.
                  i'll give that a shot next time i have access to a garage. thanks.
