Alright, I've had this problem ever since I've bought the car, it's a 93 CB7 Coupe, and what it has been doing is that whenever I'm in gear (mainly in 2nd, 3rd, 5th) my throttle tends to get stuck. It bothers the fuck out of me...is there anything I can do to try and get it to quit? I've tried messing around with the throttle body and that shit didn't help at all. Any help would be greatly appreciated.
Throttle being stuck?
Originally posted by Brandoncb7 View PostI had this happen before and it ended up being the cable that attaches to the throttle body. You might be able to get away with spraying lube down in the cable housing. I ended up buying another cable.
Originally posted by MR.PHIL View Posthave you inspect your throttle cable?from the throttle buddy to the gas pedal.
if everything seems fine then i guess you should look into that throttle body again or just replace it ,shit's getting stuck somewhere
Originally posted by cb7_ex_coupe View Postyeah kuz my guy got an ej coupe and his spring makin the peddle get stuck...
