LF a DIY for replacing a radiator support
    hi the title says it all im looking for a DIY so i can replace my right headlight/radiator support on my 92 LX. I used the search feature and can't find anything useful. plz help
    http://www.cb7tuner.com/vbb/showthre...ghlight=bumper
    also to remove the radiator support, you would need a spot weld drill bit. there about 20+ spotweld drill points on the support after you remove the bumper. you can tell by looking at the metal. youll see little circles that are size of hole punches. use the spot weld drill +wd40 and drill all those out. the radiator support should come out freely.
      what do i use the wd40 for?
        wd-40 lubes the bit so drilling will be easyer
        my new turbo build
          try it and youll definately see the difference.
