230all-motor whp on a budget
    okay watz good err1 well these r my future plans lmk wat ya'll think
    f23a1 bored 2 87mm and arp rod bolts if i ever find them.
    fully balanced rotating assembly h22a4 pistons
    h22a1 head
    comp is said 2 b 11.72
    wats the best oil pump 2 use?
    i want 2 atleast rev to 8k
    already own the h22 head and hondata s300
    here's a quick price list
    f23 avrg $300 on craigs or azht
    $300 for all my machine work and put bak together and port intake manifold
    $100 new pistons with rings
    $133 arp head studs
    $86 new bearings
    $350 for tuning at locash racing
    $75 timing belt
    $25 head gasket
    $70 cheap header
    $100 dsm blue top injectors
    $1539 and i have a complete f23a1 complete vtec 11.72 comp and around 220 230 whp i hope
    230whp on a budget? thats like oil and water man.
    you might as well just put a 100shot throttle bottle on your car if you want to be cheap.
    on a serious note, check out hondafan81's all motor build. itll give you a good idea on how to build a proper single cam.
      Might as well build a full H22 if you want to rev that high. Building an F bottom end for high reving is not going to be cheap.
      1992 Accord Wagon (RETIRED)
        What do you consider to be "on a budget"?
          I never said wat my budget was but i'm not trying 2 go over $1,000 1.5k and i'm sure it's possible just kuz i said budget don't mean ima half ass anything and im not trying 2 build it single cam i like duel cam more.
            i know the rod ratio is bad but that's y ima fully balance the bottom end and try 2 get arp rod bolts or forged rods 8k rev's shouldn't b that bad.
              well go figure opening up a block will cost you lots of money.
              one of the best headers out there right now (SMSP) runs about $800-1000.
              h22a's in a very healthy condition run about 180whp still means that you have 70whp to configure.
              you'd still need ecu+tuning
              i can go on, but its gonna go beyond on your 1000 dollar budget.
                1 - 1.5 k isn't much of a budget for what you want to do. You might want to look around the forum and check out some other build ideas. If you really are that hooked on dohc and revving, what is your argument about building an H? Much easier to do and much cheaper than the frank you're talking about.
                You'll also get better responses and more respect if you use the whole keyboard and stop typing like it's a text message. It's nothing personal, it's how we are around here. The easier it is to read your posts, the more likely you'll be to get positive responses and answers.
                  I already own the h22 head and hondata s300 ima start gathering all the prices right now also got a machine shop i been fukin wit for a while now.
                    $1500?? That will buy you a header and a tune. That's about it.
                    Past 1990 Accord EX Sedan
                    Past 1990 Accord LX Sedan
                    Past 1991 Accord LX Sedan
                    Past 1993 Accord LX Wagon
                    Current 1991 Accord EX Wagon
                      $133 arp head studs
                      $86 new bearings
                      $75 timing belt
                      $25 head gasket
                      $70 cheap header
                        i still think your not going to achieve that power with those listed.
                        telling you just do a 100 shot and take it to a dyno.
                        but if you can do 230whp under $1000 then more power to you.
                          $133 arp head studs
                          $86 new bearings
                          $75 timing belt
                          $25 head gasket
                          $70 cheap header
                          So what about all the seals on the motor? Intake manifold gasket? Oil pan gasket? Going to reuse your current clutch? What about a valve cover gasket kit? Spark plugs? Wires?
                          There is a lot missing from your list...and it adds up quickly.
                            lol ima try 2 do this and c wat happens.
                              like i said quick price list lol.
