New Clutch/Timing Belt
    I have a few questions before I purchase my parts.
    Things I need to do:
    - New clutch
    - Timing Belt/Water Pump/Accessory belts
    - Lower Tube seals
    As for the clutch, I just want a stock replacement or one that is slightly heavier duty if it's not much more and won't shatter my car. I know I'll need a new t/o bearing, clutch disc and what else? Should I be getting a new pressure plate? A new flywheel? Or is resurfacing the flywheel sufficient? T.A.S has an oem clutch for $90, bearing for $50 and pressure plate for $100, all oem. Good deal?
    As for the timing belt I want to do all the accessory belts and water pump as well. T.A.S has the complete oem kit for $150, this seems like a good deal. I'm not sure if I need new tensioners tho, are they re-usable?
    For the lower tube seals, do most head gasket kits come with those seals or is it more common to have to buy them separate?
    Thanks
    Exedy makes a very good replacement clutch, I think it would run you about $200 for the disc and pressure plate.
    $150 is a good deal for the timing kit if you don't know anyone at a Honda dealer like I do, I paid $130 for my OEM set with shop price a few years ago, but I bought some extra stuff I think, can't remember now.
    EDIT- I would replace the tensioners if they are original, my originals gave out at 180K miles and now when I do a timing job on a Honda that I don't know the history of, I just replace them. Saves expense and pain and suffering later if they go out on you, I know from personal experience.
    1992 Accord Wagon (RETIRED)
      I would definitely replace your pressure plate while your in there.. I would never just replace the disk.
      250 bucks seems steep for an oem clutch..
      Click it.... You know you wanna
      Bought from:Joshy,H22WAGON93, nho93accord,90accordLXGUY,phantomCB7,Tommi
        Thanks. It's 250 total for the t/o bearing, clutch and pressure plate, all oem.
        The tensioners are damn expensive tho for such a little part. I have a history with Honda and get a 10% discount but I think T.A.S is still a better price.
          id look at aftermarket like stated above for your clutch sounds like you can get a better clutch for about the same price..
          yeah i know nothing about timing belts i come from a v8 world lol... but clutches im pretty good with lol
            Anyone else?
              u can find a clutch kit for bout 130 bucks, (exedy ) on ebay
              and that includes the t/o bearing and press. plate...
              as for the tbelt, i say get it and the tens. pulley from tas,
              i just recetly left my balance belt off,
              so u wont need that new belt, tensioner pulley ,
              or the two shaft seals if u choose to leave it off... (preventitive maintinence)
              i think i reply'd to another thread with a response similar to this
              happy tuning
                Just an FYI, the TO bearing included in the Exedy kit has the EXACT same part number as the Honda OEM TO bearing.
                  yea that exedy oem setup is 130 on ebay. mine will bark 2nd on a good day.
