alright its just about winter here and i am going to put my car away.i am going to work on it/ take the motor out. any body got any sugestions as to what i can do while the motor is out. my budget is $1200 was $2000 but got new coil over/ shocks and other things. thanks guys.
winter time!
heres my list so far.stage 2 bisi cam,bisi pro valve springs and retainers,koni yellows on coilovers, tasautocamber kit,full bushing replace ment front and back,wire tuck,clean motor and tranny maybe polish it,drilled sloted rotors,maybe rear disk conversion,clean up enginbay,after all this i am left with$1200.
Get your head ported and polished. Get an H23 intake manifold and throttle body, and have that modified as well (tb bored and matched to the plenum, runners portmatched...) Timing belt and water pump are a no-brainer. That'd probably eat up your $1200 pretty well... but it'd be worth it.
You'll also want to look into a P06 ECU to have chipped and properly tuned (for your car, not a generic tune)
Originally posted by deevergote View PostGet your head ported and polished. Get an H23 intake manifold and throttle body, and have that modified as well (tb bored and matched to the plenum, runners portmatched...) Timing belt and water pump are a no-brainer. That'd probably eat up your $1200 pretty well... but it'd be worth it.
