AC not blowing
    AC not blowing
    Hi everyone, my AC just suddenly quit on me. Is not blowing air at all, even with the AC off. The AC fan works, all fuses checked both on the kickpanel and under hood. If i hit the AC button, I can hear it kickin, but no air coming out of the vents. Please help....Thanks
    Bad blower motor possibly. You get to get underneath the dash lol..
      You can hear the A/C compressor kick on?
      Then power & ground to the compressor should be ok.
      So the blower motor still works but no air comes out the vents?
      Did you make sure it comes out of none of the vents? Make sure its definitely not coming out before you go too far.
      If you get no air out of the vent, try the recirculated air & fresh air buttons and see if it makes a difference coming out the vents.
      If you still get no air out of the vents, check the linkage for the air distribution box. It's on the driver's side, near where your right foot sits on the gas. Look under the dash at the gas pedal, then turn your head to the right 90 degrees. there should be a white/yellow arm and a metal rod in it. Make sure it moves when you change the vents from Defog-Floor-Floor/Center-Center... if it doesn't move the problem may be in the climate control head unit.
      If I recall correctly, Honda uses 2 different Climate Control Head Units. One with cables, the other is electronic (or Vacuum ?).
      If it comes down to this, Alldata has great flowcharts for Honda.
      Dave
        got it done!, it took me several hours to do it. I should've went to the DIY section in this site.
          so what was it?
