is it hard to change pistons in an f22a1.some one told me u can remove the oil pan and disconnect the rods to pull the out the pistons. is this true or do i have to rip the block apart.
change pistons
Originally posted by deevergote View PostAnd what do you mean "rip the block apart"?
Originally posted by 92smokeaccord View Posti need new piston rings. i got some extra $ so i figured id buy the bisimoto perfomance pistons.
If you skimp out, you could have compression issues and piston blow by, not worth it.
Performance and backyard don't go together for reliability. Now, if you were just installing new rings on stock setup, OK.
Originally posted by 92smokeaccord View Posti would have to have my block bored any way cause the pistons im lookin at are 86mm. +1 over stock.
I used the Wiseco 11:1 85.5mm pistons (purchased from this site) I also had my block bored and honed.
http://www.raceeng.com/p-10338-honda...mm111-set.aspx
They also have 85mm as you can tell as well. Honestly though, I would go with Bisi because no matter what you will have to have the cylinder walls worked for proper clearances.3 CB's gone....
1 WK Overland....
Still miss the CB though......maybe one day.
if you are changing to different pistons/rings, it is highly recommended to get AT LEAST a hone. even if they're stock pistons from another used car, or brand new stock pistons, it will need a hone. part of the break in process is the rings creating a unique groove with the cylinder walls. when you swap to different ones, they won't match up.
if you're going with larger pistons, you will need it bored out (bore is the diameter of the piston/cylinder wall) the larger pistons like you're wanting you will require the engine to come out of the car and then stripped to just the block. the cylinder walls in the block will then need a larger bore done by a machine.
to answer your question, you will need to have the engine out and machine work done if you go with larger pistons. expensive, but may be worth it in the end if you want the most out of your accord.90 ACCORD EX..<-- MR thread
Originally posted by 92smokeaccord View Posti really dont want to 86mm but i couldnt find 85mm performance pistons. if u know of some please leave me a link or 2.
www.raceeng.com
Originally posted by xaaronx View Postif you are changing to different pistons/rings, it is highly recommended to get AT LEAST a hone. even if they're stock pistons from another used car, or brand new stock pistons, it will need a hone. part of the break in process is the rings creating a unique groove with the cylinder walls. when you swap to different ones, they won't match up.
