how much better is the F22A6 compared to the A1 and A4?
difference in f22 motors
the F22a6 has 140hp and 142 foot pounds of torque while the a1 has 125hp and 137 foot pounds of torque and the a4's got 130hp and 142 foot pounds of torque.
the main advantage you get from having an F22a6 is the PT6 ECU and stronger valve springs for an upgraded camshaft.IF, implies a possibility.
The internals are pretty much the same as the other F22a's. Really the only difference is the Cam, valve springs, windage tray, oil cooler, intake manifold, and exhaust. There may be a few other things I am forgetting.
Besides your auto tranny will explode before you hit any numbers that will kill the engine.
Originally posted by recliner54 View Postha i looked at that thread earlier. but like i know thw A6 has a more aggressive cam than the A1 and A4. what about the other internals and how much power would an A6 be able to handle with stock internals?IF, implies a possibility.
http://www.cb7tuner.com/vbb/showthread.php?t=2861
F22A1:
125 HP @ 5200 RPM
137 LB-FT @ 4000 RPM
8.8 :1 Compression Ratio
F22A4:
130 HP @ 5200 RPM
142 LB-FT @ 4000 RPM
F22A6:
140 HP @ 5600 RPM
142 LB-FT @ 4500 RPM
Originally posted by recliner54 View Postim going back and forth on the boost. i would like to have internals than can handle it so if i do decide to boost it i know i wont have to do anything internally.
Sleeving also helps in maintaining strength; stronger pistons [maybe even forged if you've got the money, also depends on how much boost you plan on implementing]; and most definitely get some professional advicelol
Dont forget about the dual runners!
Originally posted by JarrettIs there a goal you're trying to accomplish besides looking dope as hell?
You will NEVER get to 300hp with stock internals NA. Boost, you're going to need a good tune, a healthy motor, and good luck to pull that off for any amount of time.
The F22A motors all have the same internals. Accrdwgnguy listed all the things that make the F22A6 different from the F22A1 and F22A4 (the F22A4 is identical to the F22A1 aside from the exhaust manifold)
