Alright i was driving the other day and pulled into gas station and car died so said ok.. went in and got etc.. and came back out car started right up and was missing . But the funny thing i just did a full tune up on it a bout 6k ago and been running fine and all of a sudden . So go home and checl plugs and to of my spark plugs are beent like smashesd the tips and im lik e okkk.. so i went ahead and replaced them and not even hundred feet start missing again.. so just parked it no oil in sparkplug's oil seal good and valve cover gasket good so need help ????
running issue's
Did you recheck those two plugs to see if the same thing happend? Also this sounds stupid but it will cause it to run weird. Depending on what kind of wires you used when you did your tune up, if they are touching the bottom of the hood it can cause it to arc and miss. I had this happen on my eclipse from a wire rubbing the bottom of the hood and eventually it started arcing on it and making the car run bad. With the two plugs like that though I doubt this is what's happening.
yea i ll check but ppl were telling me timing might be off im like no cause didi it right and replaced my water pump to so > and ive made two trips to huston in it since tune up and timing belt changed but i even went to dealer to buy factory wire;s cause autozone and oriley's suck butt!!! haha
Originally posted by dirtycb7 View Postdone a compresion test what a valve leak ? and someone told me to do a valve job !
