Timing belt/gear/washer question
    I'm changing the timing belt on my F22A6 and I've looked at the timing belt sticky. But my question is about the washers and gear on the crank. Reason is the belts been changed before by the previous owner and I wasn't sure if it was done right because th crank pulley appeared to had been rubbing on the timing cover.
    So when i remove the crank pulley and timing cover, there is the balancer pulley, crank gear and a washer. On other honda motors I've done, there is a washer on both sides of the crank gear. This is where I'm unsure of on the F22. And in the diagrams in the timing belt sticky, it does not show or mention anything about this.
    Thanks,
    Zol
    WTB: rightside jdm 1piece headlight or just glass.
    On the F22As there's a washer on the inside of the inner timing belt gear. There is not a washer between the BS gear and the timing gear though.
    VTEC G27? = ???whp ???wtq
    VTEC G23 = 220whp 191wtq
    nonVTEC G23 = 200whp 183wtq
    K24 iVTEC hybrid = 260whp 210wtq
      thank you sir.
