Where is the o2 sensor?
Where is o2 sensor?
Where is o2 sensor?
http://www.cb7tuner.com/vbb/showthread.php?t=155493
NY
Follow @cb7_society on Instagram
h22 swap fund - $24.95Tags: None
no the actual wire not the insert holehttp://www.cb7tuner.com/vbb/showthread.php?t=155493
NY
what happen was i just got my headers installed from a shop and im assuming the guy forgot to put the o2 sensor backso i was trying to find out where it can possibly be so i can replug it but i cant find it.
NY
you think it could have fallen off?http://www.cb7tuner.com/vbb/showthread.php?t=155493
NY
Originally posted by tweezy View Postwhat happen was i just got my headers installed from a shop and im assuming the guy forgot to put the o2 sensor backso i was trying to find out where it can possibly be so i can replug it but i cant find it.
If I remember correctly, the O2's plug should be near the front of the car, to the right of the battery. If I had an engine bay pic I could point it out for ya...
Ninja edit:
What brand of header did they install? Some aftermarket headers have the O2 sensor installed down lower, practically under the vehicle.
Originally posted by MR.PHIL View Post^^
_________________________
since they did not plug anything in,your harness should be hanging right by your oil filter .
My O2 sensor plugs in around the area I highlighted (can't find an exact picture)...
Phil, he didn't circle the sensor... he circled where it plugs in on the harness.
It depends on the header that was installed. Stock, the o2 sensor on the F22A1 is in a different position than the sensor on the F22A6 (I forget where the F22A4 sensor is... I think in the same place as the F22A6, but I'm not positive... someone will provide that info).
Since the header is aftermarket, we need to know what we're looking at. Some header manufacturers, knowing that the CB7 has two different sensor locations, put TWO bungs on the header. One is used, one is plugged. I believe Megan Racing does this. Others sell headers made for a specific engine, with the bung in the same location as the stock bung.
Now, unless you already have an o2 sensor plugged into one bung, and the guy that put your header on didn't bother plugging the other one... there is only one thing that I can think of... he cut the wires and disposed of the o2 sensor completely. If that is the case... he damaged your car. You need that.
Take pictures of what you have. Get a top shot like the one frootloops provided, and get one from underneath, showing your downpipe. That way, we'll know what you're looking at, and we can help much better.
