Replace Idler Pulley during timing belt replacement?
    Is it a very good idea, a good idea, or totally optional to replace the idler pulleys when replacing the timing belt? I'll be doing the water pump at the same time, but the idler pulleys add about 30 bucks plus shipping to the job.
    Good things happen to people who know me.
    If the idler pulley seizes then your timing belt will go with it. So it is either a good or a very good idea to replace it.
    If you like to scrape a nickel till is screams like I do then just examine them and see if any grease has escaped from the bearing (you will see a grease track if it does), and if so replace the pulley.
    Really, the safest thing is just to replace it, particularly if you think it is 90,000 miles old or so.
