Repair: Driver Side Window
    My driver side window just shattered after it fell off track and i need to replace it and was wondering how hard it would be.Also is there any website that would have the motor and the actual window?
    Thanks,
    Bulldoze
    This is the kind of thing that you have to do yourself to understand. Its not really that hard. You just need the right tools and patience and work in an orderly and organized manner.
    I personally replaced a window motor(had to remove and re-install the window too), its not necessarily rocket science.
    You might need a Philips/flat screw driver, a 10mm wrench, and a 10mm cube.
    PS: The door handle has to be pushed to one side in order for it to be removed, and yes, you have to cut the white plastic lining inside the door.
    Accord 93 LX: H23 intake mani, Ebay short ram, P12 ecu, Full exhaust. Lots of noise... and that's about it, just noise. LOL
    Mazdapeed MX-5 04: Begi Intake, Forge BOV, Ebay FMIC. Whoooooooosh... Phhhff!
      Thanks we worked on it yesterday and realized the track is bad so it has to be replaced.
