hey hows everyone i sending my head out to get work done at a machine shop due to blown head gasket and something rattle inside my head while driving what should i get all done to it when they have it im looking to build all motor or possible turbo it but i heard bad things about turbo on the h22a thats what i have jdm so anyhelp thanks sending my head out tommorrow at a local shop thanks agian
what should i got done to my head when i send it to a machine shop build all motor
Originally posted by PointBlank View PostPunctuation is the first thing you should have worked on.
The only thing you need to get done is getting it milled/decked. Everything else is recommended and not necessarily a have to.
Anything else depends on your funds. You could get an 'n (any number)' angle valve job for the valve seats. Port and/or polish is always and option that lets the air/fuel mixture flow smoother and easier as well as the exhaust gases. Even further you could get it degreased or hot tanked, but with patience you could do that yourself.Last edited by Straight Success; 10-11-2009, 08:36 PM.The Lord watches over me!
- D. Chappelle
True it is the beginner forums yea they ask questions about things they dont know and will be happy to help them or direct them to people we know that can help them. But how can we help them if they cant type right or pronounce the words right? Sure some of us know the textn language but there are some of us that dont know it or just dont like it. Its more clearer and understandable if its written with sense.Originally posted by foamypirate View PostI think some people are forgetting that this is the beginners forum...
Originally posted by DejectedAngel View PostTrue it is the beginner forums yea they ask questions about things they dont know and will be happy to help them or direct them to people we know that can help them. But how can we help them if they cant type right or pronounce the words right? Sure some of us know the textn language but there are some of us that dont know it or just dont like it. Its more clearer and understandable if its written with sense.
The only information given in this thread about the question at hand is false... You don't want to mill your head unnecessarily. Have the minimum amount of material taken off the mating surface as possible.
Are you just having it refreshed, or are you building it for performance. If you're not sure what you want to do in terms of turbo or NA, make up your mind before having your head worked on.
And please... show some respect to those you are asking for help. 10 people have replied, 2 of which have actually attempted to help you. All 10 of those people would've offered some useful information if they could understand you. If you want us to make the effort to share our knowledge with you, please show proper respect in making the effort to type your question so we can read it!
I'm seriously going to just start banning people that can't type coherent statements. They're bad enough when they're asking for help... but once they start GIVING help, it could result in people damaging their cars because the help they got wasn't clear!
Originally posted by deevergote View PostThe only information given in this thread about the question at hand is false... You don't want to mill your head unnecessarily. Have the minimum amount of material taken off the mating surface as possible.The Lord watches over me!
- D. Chappelle
Milling and decking are pretty much the same thing, to my knowledge. Decking is usually done to the block, while milling is the head. Both involve shaving material off. If the head is warped, then it's necessary... and it should be done as little as possible. If it is not warped, then it should not be done. Shaving material off will change valve timing. It will increase compression, but there are better ways to do that. High compression pistons are the best way. If you want to get truly extreme, you can add material to the combustion chambers and totally rework them.
Originally posted by deevergote View PostMilling and decking are pretty much the same thing, to my knowledge. Decking is usually done to the block, while milling is the head. Both involve shaving material off. If the head is warped, then it's necessary... and it should be done as little as possible. If it is not warped, then it should not be done. Shaving material off will change valve timing. It will increase compression, but there are better ways to do that. High compression pistons are the best way. If you want to get truly extreme, you can add material to the combustion chambers and totally rework them.The Lord watches over me!
- D. Chappelle
Also, on another note, as an engineering major you learn things about metals and materials, especially materials engineering. There are ripples called cold wells that form when metals get heated and cooled over long periods of time. To the naked eye, a surface may seem perfectly smooth; however, we learn about things such as cold welling, warping, and other stuff. Hence why I said milling/decking. That is highly recommended by any machine shop when performing almost any type of block head work. Most machines shops know the threshold for removing material for certain heads without interfering with everyday operation.Last edited by Straight Success; 10-12-2009, 12:46 AM.The Lord watches over me!
- D. Chappelle
dont forget Take inside bro the hat of car and when building the hat bro can has get valve change . If money aloows can porting bro adding flows mabbe get your silindars bro hoed out and check othar thing .
aowokkwwo, BRO owkowito;a'tg0v. Do that too.
Handle on valve cover for easy lifting!
Here's a link that might be of help to you.
http://answers.yahoo.com/question/in...5083916AANbIBf
