i was wondering if i could get rid of my ditrubuter and use a coil pack or something like that.. if i could what would i need? and how would i do it?
distributor elimination
Many have talked about this on other forums, trying to run cbr or multiple coils. You could with an aftermarket stand alone ecu. Honda based ecu programs like hondata and all the other chipped programs won't do it because the ecu can only send one coil signal. there are other sensors required as well like a cam angle sensor etc. I found this on another site http://www.nengun.com/ultra/hyper-ignition-system-9980 That could do it, but for $800+ for just this piece isn't really worth it.
In all honesty, you can make 800+ with the stock distributor (from experience) so i'd spend your money else where.
-Zol
WTB: rightside jdm 1piece headlight or just glass.
There are a number of high-end standalone engine management systems that use coil packs, or a coil on plug setup. Electromotive's Tec3 system does that.
Other than doing something different, there's really no point to it. If the stock distributor can handle up to 800hp... you'll NEVER need to put down that much! Anything over 600 is damn near unstreetable in a FWD 4 cylinder Honda.
I have to agree there.
That's a pretty pricey and complicated thing to do for looks though!
In a brief Google search, prices appear to be about $1600.
To do a custom setup using coil packs from other cars, it would probably actually be MORE expensive and problematic in the end. For $1600 or so (a used unit would be cheaper) you'd have a system made to work together, and a high quality standalone as well.
Of course, without the mods needed to make such a system worthwhile, it'd still be a waste.
Originally posted by reaction360 View Postno dizzy and individual coils do look baller.
I guess im lucky.
It's not going to be cheap dude. Check out Bisimoto Engineering website for prices below.
You need engine management like AEM EMS 1040. You need 4 coil on plug (short). You need a CDI, like AEM twinfire. AEM engine position sensor module, replaces dizzy. All adds up, but atleast Bisimoto has a sale on AEM products now. Lastly, you need to be tuned.
