So last week I bought a 91 lx with an f22a1 in Virginia Beach and drove it 5 hours back with no problems and even to work a couple days alter. A couple days ago I switched out the valve cover and decided to flush the radiator so I jacked the car up and drained the coolant and added the flush with thermostat and water. I went to start the car to elt it idle to temperature and the car would just turn and turn and not catch. I've tried plug's, wires, dist. cap and rotor button and a new coil. I feel like it's getting fuel as I can smell the fumes and it osunds like the fuel pump is working and it gave no sign of having fuel problems. Any ideas? I feel like it's something obvious I'm just overlooking.
Wont start?
Did you replace the igniter? Everything else that you replaced are things that I would have suggested as well.
Otherwise, check your battery cables. Make sure they're clean and tight, and that the battery is fully charged. A weak battery connection can crank the car, but not start it. I spent $300 on a new battery and starter once, only to find that the only problem was dirty cables!
So I've replaced the whole distributor I wasn't getting spark inside the cap but now I am but it still turns and turns. I bought a fuel filter just in case but I haven't had a chance to change it out. I've also had it jumped off my Civic while trying to start it with no luck still it's really frustrating that it worked just fine and now this and I can't figure it out1991 Honda Accord EX
Short Ram Intake
APC Exhaust
http://www.cardomain.com/ride/2682565
there's usually a ground that goes from the chassis to the valve cover, did you forget to put it back on? Also, check the firing order.. considering you did something with them
Originally posted by Juice21thnx pimpette, your car inspired me to go lowerOriginally posted by GameChewerShiit i heard that, you heard the queen!
The new distributor... does it have an igniter and coil installed in it? As far as I know, new distributors don't come with these parts already installed. You have to add them. And if yours are bad, then the new distributor won't do a damn thing.
It will often start with the wires in the wrong place... it'll just run horribly.
