So i replaced the temp sensor thats under the distributor and the haynes manual outlined some test that you can do to check if the unit is faulty or not. I disconnected the the plug that goes to that sensor with the engine completely cold and grounded it out with the ignition turned to on and checked the temp gauge on the cluster and the reading went all the way past the H mark again, and when i took the grounded wire off, the temp gauge fell back down to below C. So does this mean that theres some kind of short in the wiring ? cause i know that its not the sensor cause its brand new. hhhhmmmmm. ......this is really comfusing the hell outta me . guess id better start checking for shorts before i start throwing any more cash at this problem.
Temp Gauge Acting Funny :(
