Hey there all well i have a bit of a problem, when i turn my key to the on position with the engine cold , the temp gauge jumps up past the H mark right away , even before the engine has had a chance to warm up . could this be a cooling prob or something wrong with my gauge cluster. Also , my odometer stopped working a long time ago lol, could that have something to do with it ? Does anyone have any clue to what that might be ? any opinions and help would be much appreciated , thanks
Temp Gauge Acting Funny :(
Originally posted by wed3k View Postit's a one wire connection in the passenger side of the cylinder head. check if the gauge moves when you unplug it. it should go down to nothing.
It's possible. It shows that the sensor is at least sending something... The error could be in the sensor, or in the cluster reading the signal from the sensor.
The sensor would be easier and cheaper to replace, though. I'd go for that first. Even if it doesn't fix the problem, it never hurts to have a nice new sensor!
well i wanted to test the fans and other components too while i was takin things apart, I made a jumper wire for the harnesses to the condensor fan and the fan turned right on. the only thing was that the jumper wire worked great to turn the fan on when the engine was off , but once i turned the engine on i tried the jumper wire again and nothing happened. could this be a faulty relay ? or is that how its supposed to work. i was waiting for a while for the fan to turn on by itself after i reconnected the harness and ran the engine for a while but it didnt, i also just replaced the thermostat and dropped in some new coolant. could it be possilbe that the engine just wasnt getting hot enough for the fans to kick on ? these cooling probs are a pain
Originally posted by semitas View Postit might be the sensor on the water neck or the temp switch near the thermostat housing
I've heard that this is a symptom of a blown head gasket.
Just something i've heard. Maybe something to look in to.
Member's Ride Thread
Originally posted by mercyboyI'd rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
the reason y ur fan does that is because when its jumped it still has to work with ur temp sensor. there are 2 diff temp sensors in our cars. one is the normal temp which is on the head the other is the fan temp sensor which kicks the fan on at a certain temp past 190 degrees f. if u jump one the fans stay on even if the car is off. it will stay on about 10-15 min. after they stop they wont come back on till u turn ur key on again.
its def. that sensor under the distributor. I had a wiring issue though...since that plastic plug gets BAKED b/c it gets so hot, when I was replacing my headgasket on my F22, I had to unplug it. And since it was never unplugged for 14 years, the plug broke.
So do this, go to the JY and find a better condition connector and cut and splice that one onto your existing wiring. Solder it and shrink wrap it if possible. If that doesn't work, then you know its the sensor.
Its either one or the other, the connector or the sensor.
