i need an advice on new suspension!!
    hello guys i currently have some cheap coilovers in my cb7 so now i want to get new spring and struts. which spring and struts are the more stiffer?? my budget is 600.
    Turbo F22 Under Construction
    if you can save up an extra $100 you can get the koni yellows with neuspeed race springs, which is one of the dopest setups for our accords. Other cheaper options for shocks are tokico illuminas, kyb agx's, & skunk2's. There is a huge faq in the suspension section, you should read it.
    Past 1990 Accord EX Sedan
    Past 1990 Accord LX Sedan
    Past 1991 Accord LX Sedan
    Past 1993 Accord LX Wagon
    Current 1991 Accord EX Wagon
      a lot of the budget is going to revolve around how low you want to go and how well you want it to handle at that height. if you're not looking for a super low right (a little less than a -2" drop) you can have a good setup for about ~$500. if you're wanting to go maybe -2" to maybe even -2.5" you'll be looking at a little larger price because you'll need higher end struts to handle the lower drop.
      i personally went with RS*R Down springs for the 94-97 accord (-1.8" front and -1.6" rear) and Koni STR.T struts. that setup will cost you a little less than $500 altogether. if you go any lower or just want incredible struts, Koni Sport struts (yellow) would be the perfect choice as fatboy1185 said.
      90 ACCORD EX..<-- MR thread
