My car wants to take off with no gas
    In the process of fixing me heater core I took out my fuel injection unit and in the process removed all vacuum lines to it. After attaching all lines as they were my car is idling very weird. It idles at about 1200-1300rpm and actually switched between gears rather violently. I've also noticed that when I put the car into drive or reverse it takes off rather quickly without my foot on the gas. ANYONE HAVE ANY SUGGESTIONS? THANKS ALOT GUYS!!!!!
    fuel injection unit? are you by chance referring to your intake manifold and fuel rail w/injectors?
    The Hatch < < - - - - - - - - - - - - - - My Cars - - - - - - - - - - - - - - - > > The Accord
      check your throttle cable. sounds like it needs adjusted.
      90 ACCORD EX..<-- MR thread
        make sure you put the vacuum line where they go. check the vaccum hoses to see if one is broken. It sound that you got a vacuum leak
        Accord Of The Month January 09
        Accord Of The Year 09
        My 2 Babys
        BMW TECH FOR 15 YEARS
          yes
            Sounds like your throttle is sticking, while at idle pull back on the throttle and see if the rpms drop.
            My s13 Ride Thread>>><<<My Rx7 Ride Thread "What is power without control?"
            New people click here
