i'd like to get pistons, rods, and possibly a crankshaft also. any ideas? i'm thinking wiseco just because some1 gave me a sticker a long time ago and its been on my car forever (ricer-ish i know). not a very good reason to choose internals, but i have little to no knowledge of pistons.
Want to build my f22a1
2013 Ice Cream Cruise!
VIDEO: 2012 Ice Cream Cruise
VIDEO: 2012 Ice Cream Cruise part 2
The single largest cruise in the Midwest!
August 3 ~ Omaha, NE
By 1320 Video
Member's Ride ThreadTags: None
i've thought about both and honestly i'm not sure which i wanna do. i love turbos hands down and have always wanted one but i also love the respect that is given to N/A builders that can hang. However, i guess i'm leaning a little more towards a turbo build.2013 Ice Cream Cruise!
By 1320 Video
I would first develop a plan of what your route/goals are that you can afford over a period of time. BE REALISTIC!!
Then, piece together parts NEEDED to make this setup work. Do research on every part, for the best product you can afford.
Pistons and rods will become a part of that list, if you surpass a stock block's capability in your plans.
The OEM crankshaft will suffice, F22ax are forged and capable.
sounds good. so stock crank, and if i turbo i'll want lo compression wiseco pistons, right? and then what should i look for for rods? i heard eagle is a good brand.2013 Ice Cream Cruise!
By 1320 Video
do h22 or h23 rods work with f222013 Ice Cream Cruise!
By 1320 Video
Originally posted by theSOB View Posti'd like to get pistons, rods, and possibly a crankshaft also. any ideas? i'm thinking wiseco just because some1 gave me a sticker a long time ago and its been on my car forever (ricer-ish i know). not a very good reason to choose internals, but i have little to no knowledge of pistons.Bisimoto Engineering
1) Call 1-888-9BC-MOTO(888-922-6686 ext. 1) Mon-Fri 9am-6pm PST
2) Email me, robert@bisimoto.com
3) Contact me on AIM, robert@bisimoto.com
Like Mr. Phil and Hondafan81 both stated the first things you are going to have to figure out is if you want to go forced induction or stay NA, and to set yourself a budget. Depending on the condition of your motor right now you could buy a turbo kit and tune it and have a pretty decent street car without having to upgrade the internals. But if you are wanting to run higher boost then you will definitely want to upgrade your internal components. The possibilities are endless it just depends on your funding and/or how patient you will be during your build. Either way you decide to go good luck with your build and keep us updated on your progress.
thanks for the info guys! i really want to upgrade internals. i'm leaning a little more towards a turbo build. the reason i asked about the h22 rods working in our engines is because i see this package on ebay http://cgi.ebay.com/ebaymotors/Wisec...Q5fAccessories and they dont have it for the f22. i would go with the 87mm at 8.5:1 and bore my block out to 87. another question, if i do this, would i be able to drive alright with this low compression w/o a turbo right away? i just wanna be able to drive it if my funds run out for some reason.2013 Ice Cream Cruise!
By 1320 Video
The F22A's compression ratio in stock form is 8.8:1, so 8.5:1 shouldn't make that big of a difference. It will probably feel (and be) a bit weaker, but it should run well enough.
I'm not 100% sure about the H22 rods, so I'm not going to mislead you with a guess.
You could always contact the company on there that is selling that setup and ask them if they can get F22A rods, and give you the same package deal. If they can, I'm sure they won't turn down a sale!
You may also want to try www.bisimoto.com. Bisi takes good care of CB7tuner members, and you can be sure that you'll always get the right stuff from him.
i cant find the chinese H beam rods on ebay. i got those for about 275 shipped.
i know bisimoto offers H beams and another place offers cheap H beams. i want to go with an I beam rod because the potential 250hp probably wont even exercise the H beam.
depending on the hp estimate, you can probably go with a stock rod with ARP rod bolts. ARP main and ehad bolts are a must.
I would go naturally aspirated with 11.5:1, 86mm forged pistons, a streetable cam and a good tune and that will probably get you between 30-50 horsepower (depending on cam and other bolt-ons) over a stock engine.
Even if you make a ton of power in NA trim you'll not be very happy with it until you change the F-series gearbox's final drive or upgrade to a Prelude or Accord type-R transmission (M2A4, M2F4, M2B4, T2T4 etc.). Just swapping the gearbox will dramatically change your car's acceleration since it's a performance oriented gearbox over the Accord's economy oriented gearbox.
Just my 2¢VTEC G27? = ???whp ???wtq
VTEC G23 = 220whp 191wtq
nonVTEC G23 = 200whp 183wtq
K24 iVTEC hybrid = 260whp 210wtq
