where oh where is my power?
    got vtec hooked up (meaning no vtec cel) but still i dont believe its working
    and still its sputtery and weak
      bump
      need help guys
        Do you have any CEL at all?
          wowowo.. you guys all fail to notice.. he said he THINKS its a h22a4.. you should post pics for conformation
          You don't have to like what he did, but I would hope that you can appreciate the time, money and love that went in to the build. If you can't, you're not really an enthusiast, just another dumb kid with a car.-visualpoet
          Money and Knowledge are never in the same sentence, because people with Money think they know it all, but people with knowledge, know better.-ragingasian
            If he did that, he'd be a conformist.
            If the block says H22A4, then it's an H22A4. If he converted to OBD1, then it's an H22A4.
            Of course... that leaves an interesting question... AndoCommando, what did you do about the OBD2/OBD1 situation? You DID convert the motor to OBD1, correct? OBD1 dizzy, ECU, and injectors?
              yes sir its all converted i got a jdm p13 obd1 injectors and an exturnal dizzy that seems to run my car so im assuming that its obd1 but i have no idea how to check
              the only cel is for my primary o2 sensor that is not hooked up
                i never said that
                in my first post i said i thought it was all done
                i know its an a4
                  If the dizzy plugged into your stock plugs, it's OBD1. It is important that it's an H22 dizzy, though. I don't know if any other would bolt up...
                  Hook up your o2 sensor! If you don't have that hooked up, your ECU is running in "closed loop" mode... basically, dumping large amunts of power-robbing fuel into your engine, because it has no idea what the oxygen intake is like. Additionally, with the CEL on, the ECU is probably causing the car to run in "limp mode", which means there will be no VTEC.
                  Jesus Christ... fix the things you KNOW are wrong before trying to figure out other things! We just spent an entire page trying to diagnose something that was most likely the fault of that o2 sensor and CEL.
                    wow i feel retarded...
                    i will get that hooked up right away
