When I removed my p/s and accessories there was a lil ground wire that ran from the Valve Cover to the p/s pump then to the motor mount. Well with the p/s deleted do I still need this ground and whats its purpose. Thanks
Ground or is it?
Yep it is a ground, its there to ground the valve cover.
Many people have removed it without any issue.
My 5.7 LS1 Holden Ute
Personally, I would reroute the ground, perhaps grounding it to the engine block where the power steering pump bracket connects to the engine block. there's a lot of voltage (though not a lot of current overall) moving through the valve cover so I would think that it would be best to provide that ground as an alternate safe route back to the battery, in the event that that ground becomes necessary, although it may be true that many have removed it without incident.
I never really thought about it before, but most of the current in the valve cover from the spark plugs probably usually grounds through the four valve cover bolts down into the block and then to the battery. But you never know when an extra dedicated ground would come in handy, so I would guess (not knowing) it probably is designed as a backup, since the wire is of such small gauge. If you get some extra charge in the valve cover that can find an easier route back than through the valve cover bolts and that little extra ground isn't there to route it down to the block then the current could go someplace weird and cause an unpredictable problem.Last edited by batever; 10-05-2009, 09:54 PM.
Originally posted by batever View PostI never really thought about it before, but most of the current in the valve cover from the spark plugs probably usually grounds through the four valve cover bolts down into the block and then to the battery.
