okay so i'm installing my rear struts and everything is going great. i tighten the very top nut on the rod as far as i can go and figure it should be fine. why wouldn't it? well i get them on and i press on my trunk to test them out a bit and i hear a clunking coming from where the top mounting part is. am i missing something here? did i do something wrong?
i've got Koni STR.T struts with RS*R 94/97 springs. it almost seems like i need to add a washer because i ran out of threads to tighten anymore..
one more thing, i also noticed the stock struts have like a built in washer on the struts where as my konis don't. could that have something to do with it?
edit: just read a koni install thread on h-t and it showed the guys koni yellows with a washer on the rod. my don't have this. wtf? is this probably why it's doing that?
