When I turn my wheel while driving there is this whining noise, sorta like a dog whine. I had a CB before that did this too so I know somebody else has had this problem. Power steering fluid is fine so its not that. Could somebody please tell me what the hell that noise is and how the hell I can take care of it without replacing the column?
Whining in my steering column?
mine did this too and it just doesn't do it anymore. no clue as to why but when i first got the car it was making the whining sound that almost sounded like it was coming from just under the dash90 ACCORD EX..<-- MR thread
I'm actually having and issue with my steering components? When turning at slower speeds left or right, I will get a strange sound like something rubbing in the column. I have inspected numerous things to no avail. Does your steering wheel get hard to turn at all? have you done anything under the dash to have something rub on the column?
Originally posted by nightime25 View PostI'm actually having and issue with my steering components? When turning at slower speeds left or right, I will get a strange sound like something rubbing in the column. I have inspected numerous things to no avail. Does your steering wheel get hard to turn at all? have you done anything under the dash to have something rub on the column?
one member had this recently in his cb in this beginners section. if u would use the search function u would find his thread. in it he stated that he took his wheel appart and tightened the big bolt holding it. i would lube everything up. check your fluid. jack the front wheels up just enough to freely turn the wheels w.o them rubbing the street. turn your wheel all the way to the left and right 50 times to get all air bubbles out the system. ONLY USE HONDA STEERING FLUID. trust me it makes a difference.
i rebuilt my p/s pump in my front yard on my 3g prelude about an hour and a half and i can turn the wheel with my pinky.
a friend of mine had this annoying noise in his 92 bmw 3 series and he just lubed it up and it went away.
you state you can turn find so i dont necessarily suspect anything wrong with the rack and pinion. break out the vasoline
