I am having trouble finding a pulley set for my cb7. are there any sites where i could find one or would a h22a kit work on a f22a?
pulley set
Originally posted by xkjnboix View PostOBX made pullys too. i got one of their p/s pump pullies
UR pulleys are properly balanced. Cheap knockoff brands may not be. OBX is a knockoff brand, though one of the better ones...
The accessory pulleys are fine... the worst they'll do is ruin your PS or alternator. The crank pulley, if not properly balanced, may cause oil pump failure... which will destroy your engine. UR crank pulleys have been blamed for oil pump failure as well, though I've never had that issue, and I've been running one since 2004.
The crank pulley gives the most power out of the set.
Also, AEM makes, or at least used to make, accessory pulleys.
H22 pulleys would probably work. They'll fit, they'll be functional, and they SHOULDN'T cause damage...
Originally posted by F22Cb7Rid3r View Postdude dont touch the UR crack pullys i had one on my new engine rebuild and it tore up the timing cover and rubbed all the time. i should take a picture of my old one it turned out like a worn brake rotor on one side
Originally posted by deevergote View PostThey aren't made anymore for the F22A. As the OP mentioned, he could use H22A pulleys, but it wouldn't necessarily be the best idea.
The best way to find them is to look on ebay.
I wouldn't trust any crank pulley other than UR (unorthodox racing is the actual name of the company)Last edited by Shadow1; 10-08-2009, 08:42 AM.
Originally posted by deevergote View PostI figured I'd add it for those that don't know. Some people don't have the searchy skills necessary to figure it out.
i just went on ebay. found them for a crap load of other cars. just not the CB. went to UR's site and they have it up there for the accord and prelude. but you'll have to find a dealer as i cannot find where to buy it on the site.
