i was just curious how do any of yall get a good launch with an auto. i dont wanna neutral drop too much, but that seems to work best. any suggestions?
Launching in an auto?
This topic is closed.
http://www.cb7tuner.com/vbb/showthread.php?t=155493
NY
Follow @cb7_society on Instagram
h22 swap fund - $24.95Tags: None
brake launch....keep the car in drive, while holding down the brake fully rev the engine, then when your ready to go, let go of the brakes and fully press down on the gas.Dragnskull <3 Tacit says:
*i dont understand how people can even work on these piecse of shit
*theyre the emachines of cars
Leefhead says:
*that sums up GM in a single sentence
Originally posted by tweezy View Posti was just curious how do any of yall get a good launch with an auto. i dont wanna neutral drop too much, but that seems to work best. any suggestions?
your tires might spin quite a bit though
i wouldn't shift down from neutral, it feels like im gonna break the tranny.
check out this vid. launching at 2500rpms
Neutral dropping will destroy your transmission VERY quickly. The automatics in our cars are often in poor condition by the time we get them anyway, because people don't properly maintain them (regular fluid changes with Honda fluid are a must... most don't change it, or if they do, they put in something cheaper)
As the others have said, brake launch. Practice with it to see what works best for you.
I have had my 1997 Honda Accord EX-V6 (C27A4) since 2002 and dropped it from a neutral rev for the first time the other day. It was scary, it sounded like someone took a sledge hammer and hit the side of my car; stock, my car runs 168.9 ft-lbs of torque. I will not be doing that again.1997 Honda Accord EX-V6:
Originally posted by James MatteuYou have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
Originally posted by deevergote View PostNeutral dropping will destroy your transmission VERY quickly. The automatics in our cars are often in poor condition by the time we get them anyway, because people don't properly maintain them (regular fluid changes with Honda fluid are a must... most don't change it, or if they do, they put in something cheaper)
i agree, dropping from neutral will destroy your tranny, i did that once and will never do it again
thanks guys. ill try that as soon as it stops raininghttp://www.cb7tuner.com/vbb/showthread.php?t=155493
NY
