Plugs detonating very fast,HELP.
    So,my car had been randomly missing for the past week or so,so i decide to take a look at the plugs.When i took them out they were black,and grey.They were pretty much fried.So i was like ok cool,heres the problem.I changed them and everything was fine for the next 4 days.The next day im' leaving my girlfriends house and the miss starts happening again.I get home,and the plugs are all black just like the old ones were,but i had just put them in that same week.What could be causing them to detonate so quickly?
    spoonsportsaddict
    I think you may be misusing the term "detonate".
    The plugs are black? Or gray?
    If they're black and sooty, then it's likely that you're running way rich. If they gray, speckled, and chalky, then that indicates detonation in the cylinder. Could be running lean.
    Is your CEL on? If not, are you sure it works (does it light up briefly when you turn the car on?)
      They are black and sooty.I dont believe my cel light has a bulb in it...nor does my check engine light.Could it be the tune i'm on causing it to run so rich?If so is there someway i can make it run leaner till i get the money for a new tune?
      spoonsportsaddict
        It could be. If you have a custom tune, then I really couldn't say what it was unless I knew what was done. The o2 sensor might be bad as well. Get that CEL fixed, and it'll tell you the problem.
          Its just a ls/vtec basemap with more fuel ,two step,and 4500 vtec.
          So my o2 could cause it to run this rich?
          spoonsportsaddict
            If the o2 is shot, it'll just result in the ECU dumping excess fuel to keep things safe. It's also possible that your map is too rich... and that could end up killing plus, as well as the o2 sensor. It's that "more fuel" that makes me think that is the case.
              Well his "boy" street tuned it...so i knew it wasn't going to be the best tune in the world.Would trying a virgin p28 and seeing what happens healp diagnose the tune problem?
              spoonsportsaddict
                Potentially. I don't know much about LS/VTECs so I can't say for sure.
                Get back in a damn CB7, would you? I know what to do with those!
                  'Check Engine Light' and "cel light" are the same thing, i.e. C.E.L.
                  You need to find out exactly what was done with the 'custom tune', and then maybe undo it...
                  Or, you could just have a faulty sensor, or a very dirty air filter...
                  Regards from Oz,
                  John.
                    Since the tune isn't for your particular car, that would be the first thing I would address.
                    The o2 sensor, if it wasn't bad before, may be fouled by now. Your CEL would tell you that, if it worked.
                      I would check all the obvious things first - your filters, if the ECU stored a check engine code, wiring, etc.
                      Then get (borrow if you can) a wideband oxygen sensor with a gauge - this is basically the ONLY way to make sure that the fuel map was tuned by a knowledgeable person. Somebody may have "street tuned" it, but 1. it could have been a beginner tuner 2. it was obviously tuned for another car, and 3. all humans make mistake.
                      You could at least get the basemap file you are running(can extract it with any compatible chip burner), send it to somebody who has experience with LSVTECs, and have them look at it.
                      EDIT: when you have somebody look at your map, you can also have them disable your O2 sensor - to rule that out.
                        Did you get rid of your CB again?
                          either that or there is a exhast leak before the o2 making the sensor see more oxygen and dumping fuel to compensate.
                          or it can be a faulty fuel pressure regulator
                          easiest way to check that is to take off the vac line and see if fuel is in it.
                          Retro!
                          Hater
                            Were there any supporting mods that gave a necessary reason for richening it up?
                            Did it start fouling plugs after the tune was done?
                            I'd say its the tune causing the plugs to foul, however you need to put a bulb in and check for any codes as running rich can also damage O2 sensors
                            My 5.7 LS1 Holden Ute
                              You haven't by any chance fitted one of those 'extra 20hp' 'chips'?
                              Regards from Oz,
                              John.
