Chirping Steering Wheel
    I did some searching on this and nothing came up.
    I'm hearing this chirping noise while i am driving, off and on (depending on road conditions) and at a stop with a little motor vibration from idling. It sounds like it is coming from the horn cover. Does anyone know how i can get rid of this annoying noise?
    wtf its coming from the horn cover? is it loose? maybe its just the plastic rubbing against the rubber on the steering wheel. next time you hear it try to press down on it a little and see if it stops.
      It does stop when i do that. Also it stops if i push on two opposite corners of the horn corver and kind of twist it, that also makes it stop.
        fixed, screws on the back of the steering wheel needed to be tightened. thanks for the help though.
          ya one of my friends had this happen on his 92 bmw 3 series sedan and his just needed wd40, glad u fixed it i kno its annoying.
          frostwhite225@gmail.com =VENMO
          http://www.youtube.com/watch?v=NOB38zJu66o
          [COLOR="Magenta"]
