Originally posted by bcjammerx
View Post
http://www.bobistheoilguy.com/forums/ubbthreads.php
View Post
The issue with dirty rings and ring grooves (dirt = chemical deposits, from fuel and oil) is that this can cause the rings to become 'stuck' in the grooves. This causes the rings to lose the ability to push strongly enough against the bore walls and as a result the cylinder loses compression. This can occur even when the rings themselves are not damaged, merely not 'free' to do their job. This may be so bad that the rings can exert almost no pressure on the bore wall, or just a diminished pressure. I've seen plenty of pistons that when pulled from the engine had rings that were totally stuck in the grooves and did not spring out at all, but still had good 'ring tension' when the rings were removed from the piston.
Even if the ring is 'loose' enough to press against the bore wall as more or less intended, the bore wall / ring pressure created by the 'ring tension' (springiness) is required to create an initial seal that permits the initially low cylinder psi to get behind the piston ring, and (as the cylinder gas psi rises) to push the ring much more firmly against the bore wall than the ring tension alone can do.
If this didn't occur then the ring tension pressure alone would not be great enough to prevent high pressure gasses from lifting the ring off the bore wall and the all important gas pressure being lost. If the ring groove is clogged with crap then the gas pressure cannot get behind the ring and so cannot more firmly seat the ring against the bore wall (as it should). As a result the ring will seal much less effectively due to accreted crap in the ring grooves.
If the crap can be removed (physically or chemically), then the ring will again become free to move in the grooves and thus be able to create the initially required light pressure ring / bore contact, and compression / combustion gas psi will again be able to freely get behind the ring to firmly push the ring against the bore to create an effective ring seal.
I'm not saying that any particular chemical product can effectively achieve this ring / groove cleaning or not. What I am saying is that if it can then there is a plausible reason as to why it would / could be effective. The caveat is that even if it does work, if the ring has already lost it's ring tension due to having been overheated, then it's past help.
Do note that there seems to be a significant amount of apparently independant positive feedback (and some less than positive) concerning the effectiveness of Auto-RX (as well as 'Seafoam") on the Bobistheoilguy site. And do note that a number of people who post on this site appear to be qualified tribologists (i.e. lubrication engineers), at least they talk the talk well enough to have me fairly convinced they are what they say thay are. I doubt that BITOG is set up purely as a promotional tool for Auto-RX, but then I may be naive...
