The Short and Skinny
The car only runs if the key is held in the Start (III) position with the Gas Pedal to the floor; i.e. Wide Open Throttle (WOT). If this is done, the car runs, but the Starter grinds the entire time; which is to be expected. I am going to test the Main Relay and Fuel Pump, but would like to know more about the idle control system and how to test it. I think there may be something wrong with the Internal Ignition Coil, but that doesn’t seem to jive with the car still running with the key held in III.
The Long Story
Some of you may remember that I have a cousin in college with a 1990 Honda Accord EX Sedan 4-spd Automatic. He bought it with the idea that if anything went wrong with the car, I could fix it. Yup, this is the same CB that I am fabricating a harness for, thead. Well, not long after buying the car I finally got it into my driveway. I found an improperly installed Alternator with a damaged tension bolt (squealing belt), and valves that were way out of spec (bad taping from the valves). I fixed those two noises only to discover the ticking time bomb that was a dull rattle at 3000 RPMs. We didn’t have time to tear into it, so I asked that he take it easy and bring it back after school let out for summer. He claims to have been on the interstate (not takin’ it easy in my book) when the engine failed, thread. I dropped in a “refreshed” F22A1. I swapped over the camshaft, exhaust, and distributor from the F22A4 to the F22A1 to make the F22A1 an F22A4 equivalent. After getting the car back on the road, with cold A/C to boot, it has run flawlessly until recently. Wednesday, September 16, he was driving home and the Tachometer and Speedometer went dead for a moment, and then came back to life. Sunday, September 27, the car would not start. He would turn the key to the Start (III) position and hear the Starter running, but the motor would not fire. He held the gas to the floor and got it to turn on with the key in the Start (III) position, but the car would immediately shut off if he let the key go (still WOT), allowing it to return to the ON (II) position. He said that if he holds the key in the Start (III) position and holds the Gas Pedal at WOT, the engine will run, albeit with the Starter grinding. He called me at this point to report all that I have presented here today.
I plan to run a diagnostic on each system that is involved in the ignition and idle process, testing them in their starting order. As such, I am bringing my: probe light, extra PGM-Fi Main Relay, extra Fuel Pump, Multimeter, Fuel Pressure Gauge, and plenty of fuses. I can only verify the resistance and output signal from the Internal Ignition Coil, but don’t really understand how the coil could fail unless the key is held in the III position. I haven’t worked out what to test next; I need to study the idle control system further.
Any ideas will be appreciated.
The Long Story
