I did a voltage test on the battery and compared it to another battery in a working car. Both said 12.3 Volts.
Car stumbles on cold start
Originally posted by MIKEYZCB7 View PostI'm a nissan certified tech,I would know.the main relay controls the fuel injectors.It's missfiring at start up because the injectors aren't sparying right
I'm heading to the JY this weekend, maybe I'll grab an extra one for fun.
Cris P.
Battery got tested today and it's good! I also swapped batteries with a known good one, and the same cold start issue occurs.
I REcleaned the IAC (tested IAC and it's good) and FITV.
I doubt TPS b/c that would throw a code and car would run shitty during anytime.
My other options are main relay...OR would a belt that's too loose cause this?
I noticed after I replaced the belts they would slip a bit on cold starts, and while slipping the car wouldn't raise to high idle until the belts caught. Should I tighten them up a bit since they may have stretched a bit after replacement?
Originally posted by s2cmpugh View PostBattery got tested today and it's good! I also swapped batteries with a known good one, and the same cold start issue occurs.
I noticed after I replaced the belts they would slip a bit on cold starts, and while slipping the car wouldn't raise to high idle until the belts caught. Should I tighten them up a bit since they may have stretched a bit after replacement?I know....I'm gunna lower it
