I decided to replace the outer axle seals on both sides - and ran into a little problem on the driver side (manual transmission).
I couldn't fit the new seal in, so I completely removed the intermediate/halfshaft that goes into the transmission for better access - and even then, the new seal simply does not fit. I have a seal driver that I used along with a rubber hammer - and I could *make* it fit (lightly lubed with fresh oil), but the outer rubber on the seal scrunched up around the rim, so it's simply too large (ruined one seal, bought another).
I even tried putting the seal in the freezer to see if it might shrink a tiny bit, but that didn't help.
The intermediate shaft looks and feels pretty new, so I'm thinking that maybe it's an aftermarket replacement, and the opening isn't quite up to spec? It probably came with a seal already installed, and unless I can find the exact seal - I'm screwed.
Any ideas? These are aftermarket seals, so perhaps an OEM might make a difference, but I'm not hopeful... I foresee a visit to the junkyard in my future.
