Tach jumping around when cold
    Got an issue, where my tach jumps around when the car is cold, I can hear the motor and the RPMs are steady, but the tach is jumping. I also have a problem that seems to be a fuel issue(car dieing and running rough mainly at lower RPMs) and was about to change the fuel filter and clean the injectors, but then this problem came about.
    I recently(2 weeks) replaced the Ignition control module, cap, rotor.
    Any ideas would be helpful before i just start tearing everything apart.
    check if egr is stuck open.
    I <3 G60.
      A jumping tach is usually caused by an igniter (ignition control module) going bad. Where did you aquire the replacement igniter? Was it used? I would take it back to wherever you got it, and have them give you another one. Its not uncommon for new parts to be defective.
        too bad he already replaced it. they usually go out during driving and not at idle.
        I <3 G60.
          Like i said before, its possible that the ignition control module he installed 2 weeks ago is on its way out. (in response to the tach bouncing and not corrisponding to how the engine is running)
          As for your drivability problem at low rpm, a bad o2 sensor can cause this. (car dieing and running rough at low rpm)
          A way to check if its an o2 sensor related issue is to just unplug it, and see if the drivability problem persists with the o2 sensor unplugged. (it will throw a cel)
          To see if its an egr related issue, you can always put a screw / plug the vacuum line for the egr, and see if the problem persists. (it will throw a cel)
            A jumping tach can also be caused by a bad ground. Check all your grounds and make sure they have a good connection.
            Actually I have my EGR disconnected and the vacuum line plugged with a screw and I do not get a CEL. Weird huh?
            PARTING OUT MY 1990 EX COUPE!! EVERYTHING FOR SALE! CLICK HERE
            Listen or download the first 4 songs I completed for my new upcoming album here!!
            My member's ride
              When I tested mine (for what ended up being a bad o2 sensor), the electrical for it was still hooked up.
