Radiator Fan?
    Radiator Fan?
    My Fan will not come on while the car is on.
    After the car goes off it will kick on.
    And depending on how long I have run it and if I was in traffic it will kill my battery cause it will run for a long time.
    If the fan is on when the car is off, I can put the key in and turn it to the spot where all the dash lights come on, and the fan will go off.
    Anyone know whats going on?
    http://www.cb7tuner.com/vbb/showpost...53&postcount=4
    Well mine is vise versa! I changed my thermostat and then my fan would only come on when the car is on. But before i changed it the fan would come on when the car would be off.
      Hey guys,
      I had the same kind of issue on my 93 lx a few months back. One or more of your fan switches might be bad ( there is one located on the thermostat housing i believe and the upper radiator hose right near the head) Its a quick fix, a simple unscrew the old and screw in the new. you can get the sensors at any autoparts store.
        I have replaced the switch near the front close to the block.
        Does the one on the theremostate control the radiator fan too?
        I thought it went to the other fan for when u got really hot.
