are sleves worth it ??
    i was wonder if it was worth it to get a an h22 blocked sleved because i wanted to run like 10 pounds of boost but a guy was telling me that its not worth it just for 10 pounds..but he told me i should just get good pistons ..and also is it true theres a chance your block can crack when your getting it sleved???
    For 10psi... just make sure the engine is healthy, get a properly sized turbo and a good intercooler, and have your ECU tuned REALLY well on a dyno by someone that knows what they're doing. For 10psi on a healthy engine, with correctly sized parts and a good tune, you shouldn't need to open the motor.
    Mahle Gold Series pistons are compatible with the H22's sleeves, if you want to go that route. That's not bad advice. The options for compatible pistons are limited, though. That's one reason why most people sleeve H22s for turbo. The FRM sleeves are actually very strong... but most forged pistons will destroy them.
      ok so if i did get them sleeved there isnt a chance of the block cracking
        With enough abuse, there's ALWAYS that chance... but a good set of sleeves will decrease that chance.
        At 10psi, you'd have to do something seriously wrong to crack a sleeve, though. Even the stock sleeves should hold up to 10psi with absolutely no issues. If you don't feel safe boosting your stock block (or it's not healthy), then check into the Mahle Gold Series pistons.
          no no it runs good and its just cause its a used motor i dont no what abuse has been done to it so better to go new than to find out a month later plus im buying another block so might as well go new
            "runs good" isn't any sort of technical diagnosis. Have a compression and leakdown test performed by a competent mechanic. If it's good... you may be fine boosting the stock motor. Spend your money on quality parts and tuning.
            Though if you can afford it, you're right... new is always better, as long as you get the right stuff, and install it properly.
              i guess i could get a compression test just nervious for the results
                just curious but where can i get that done. the whole compression leak down test.
                92 LX N/A rust bucket restoration RIP
                91 DX Coupe to 9293 EX Coupe restoration
                funds for swap:$000.00
                Bought from:HondaFan81=My current CB7 DD ,CB7_Sleeper1 Koochologist Tommi mtnbikkerkid33
                Traded with: Wed3k
                  most mechanics can perform these tests. both pretty easy to do though. u will find plenty of info about both test if u search .
                  My Members Ride Thread
                    It's be better to find out now and get it fixed before you boost that motor and let it do some real damage. Measure twice, cut once. If you have any problems with the motor right now running NA then putting a turbo on it will only make everything ten times worse. It might cost you some more money to get everything going but in the long run your motor will be alot more reliable and you'll be able to spend more time at the strip instead of in your garage.
