I looked it up but i cant really find anything, How can i take out the short shifter and switch back to a stock prelude shifter since i have a h23 tranny. One of the people at autozone suggested that the short shifter could be my problem of it grinding 1st to 2nd, cause it doesnt give enough time for hte syncros or something. so i wanna just go back to stock. Any info?
Take out a short shifter
It's grinding 1st to 2nd because the synchros are going bad. Your short shifter has nothing to do with it.
Once you take out the center console to access the shifter you should be able to see how it all comes apart.Originally posted by Junior SmurffNevermind guys, google search works wonders!
I don't have road rage, my car just goes faster than yours!
Accords are for winners. And Grandmothers. But mostly winners.
I have grown so Tired of Internet Illiteracy. Please learn proper spelling and grammar. For your sake and that of your children.
Your shifter cables might be fucked...
On my 2nd CB I had a short shifter and a Gearspeed tranny... tranny was definitely not the problem. Car stopped going into gear; found out my clutch was fucked. I replace the clutch, and the car was still grinding into 2nd and 4th. Car stopped going into all gears eventually. Found out it was the god damned shifter cables. Replaced those, tranny shifted into gear beautifully
Yaw, you got the Gearspeed tranny when you bought sprinkles' car? I thought he sold that separately... Oh wait, no... I remember now. I was bummed because you sold the car before I had a chance to buy that thing from you!
The short shifter may not be what is causing the grind, but it's very possible that it is what caused the synchros to wear more quickly. Grinding when shifting is most likely your synchros.
What sort of short shifter is it? If it's an adapter, just remove it. If it's a modified stock shifter (there are quite a few floating around) the stock mounting points should still be there... just move the cables back to them. If it's a PSPEC or 4bidden, you'll have to replace it. Honestly, I would just stick to a stock shifter. It's not all THAT much further, and it will ensure smooth operation.
GM Synchromesh works very well. I had 3rd and 5th gear grinds due to a shop putting gear oil in my transmission, and synchromesh made it a LOT better. It won't fix anything, but it'll help... and it'll help prolong the life of what you have left.
"Synchromesh gear oil" is a very bad description. There is a substance called "gear oil", and it will cause major damage to your transmission (see what I wrote above...) Stay away from "gear oil".
just find install instructions and do everything backwards
check this one out
http://www.pdm-racing.com/installs/s...p/sshifter.htmViva la CB7!
Originally posted by BlackZ View Post
oh alright i got 2 quarts then.
