today i tride changing my timing belt but everything whent wrong on me first the fucking crank bolt broke and now i cant take it off so wha should i do just buy a used motor of fix it?? please help i have a f22a1 and my buget is about 300 so lmk please in what i should do and whats the easy way in doing this?
so have a problem
Originally posted by jdmboi type s View Posti think its still fixable........
Originally posted by deevergote View PostReplace it. And figure out why it broke. They don't usually just break.Originally posted by sweet91accordif aredy time i need to put something in cb7tuner. you guy need to me a smart ass about and bust on my spelling,gramar and shit like that in so sorry.
if you know a master mechanic he should have an air torque drill. Use a small drill bit and go straight into the bolt! When you do that go buy a cheap but decent torque screwdriver heat up the bolt hit the screwdriver into it then use a vice to get enought leverage on it to twist it out the heat is to loosen anything that could be holding it in. I had to do this on a block bolt on a 66 mustang and it worked with absolutly no problems.Time to Fix it Up
had this problem before, we headed to our local sears, purchased a few things, a thread tap, some kind of bolt extractor kit, and the handle( for use with both ) got it out with some patience. the replacement bolt from honda was more then a few of those tools, but dont quote me on that. rough idle at first but got it tuned afterwards.
Turbo Setup: 100%
how much of the bolt is still in the crankshaft? You broke the whole head off right?
If thats the case, then most if all of the torque has been relieved. I would then grind/cut a slot into the bolt shank with a dremel the right size for a flathead screwdriver and just unscrew it.
OR you can drill a hole and use a screw extractor/EZ-out tool to remove the piece of the bolt. Just make sure your hole size and depth are good for the EZ-out you choose to use. They sell these at almost any autoparts store. Just be very careful because the EZ-out is hardened steel and you will break it if you stress it in the wrong direction.
