After I have let the car sit for over 4 to 5 hours, It takes me about 4 to 5 turnovers to start the car. Its like the gas not staying at the front or something. I checked the fuel rail and it is tight and secure, the injectors isnt leaking. After I crank it up it stumbles for about 12 seconds then runs like new
Pressure Problem??
your fuel pump bleeds off the pressure after it sets for a while. but requires the pump to prime to the retired pressure as your cranking it will re-prime several times and then it will start, so if it is not priming enough thats usually the cause for extend crank. or it could be the fuel pressure regulator too.
Originally posted by deevergote View PostI doubt it's a fuel pressure issue.
Change your fuel filter, check (and change if necessary) your spark plugs. Distributor cap and rotor. Check your battery. Make sure it's holding a charge, and that the cables are clean and tight on the terminals.
