Drivin a 92 ex.. When my windows fog up, i turn on the ac, but it doesn't really help. I had my blower motor replaced in january, but when i turn it on high it doesn't feel like its pushin out enough air. And when i put it on my windsheild only, it only defogs the bottom maybe two inches.
Defog/Fans/AC issues..
I believe the evaporator is what removes humidity from the air with the air conditioning. As for why your blower isn't pushing out enough air could be the fact that almost every aftermarket blower motor for whatever reason doesn't seem to put out as much air as the oem. Also there is a blower motor resistor which is what controls the speed the blower motors runs at. Maybe an aftermarket resistor to match the aftermarket blower motor MIGHT help.
As for a solution to your windows fogging up, Rain-x anti-fog applied to the interior of your windows will do wonders!
Originally posted by Aries1911 View PostDrivin a 92 ex.. When my windows fog up, i turn on the ac, but it doesn't really help. I had my blower motor replaced in january, but when i turn it on high it doesn't feel like its pushin out enough air. And when i put it on my windsheild only, it only defogs the bottom maybe two inches.
You may need your AC recharged with refrigerant if you're not getting cold air. It's possible that you may have a leak somewhere in your refrigerant lines.
If you ARE getting cold air, but it's just not as drafty as it should be, your blower motor may be at fault.My pictures/photos will return soon...
no... we didnt do anythin to my ac when it was replaced. I'm not sure if it blew cold air b4.. id only had the car for bout 3 weeks when i replaced it.
What's this evaporator thing?Last edited by Aries1911; 10-11-2009, 11:38 AM.
92' Ex - Needs work, but hey! It runs safely
91' Lx -Car vs IDIOT.. R.I.P.
RIP 92' Lx... Car vs Concrete.. Car lost.
