TCU issues
    TCU issues
    My wife has a 90 Accord EX, the sport light has been on, has the typical symptoms. Well, I pulled the back up fuse, did what it said to do on here, took the car for a spin, it shifted way smoother than normal. My question is this. Can I use the tcu out of a 9293 Accord, I'd like to bypass the sport shift stuff all together.
    Anyone?
      Originally posted by nine_deuce View Post
      Anyone?
      had the same problem what i did was took out the negative on the battery for a hole 24 hours so the power will be cut on the tcu ecu and all the electric wiring so when i started it the sports light was off make sure you turn it off on the switch before removing the negative.
        Yes you can use the 92/93 tcu, i'm using one with my cb7 right now. Its also possible for you to tear apart your old tcu, and fix it. There is a resistor that burned out, desolder it, take it to radio shack, get the replacement, and resolder it back in. It should be obvious which component burned out when you open up the tcu.
          Thanks for the replies. She doesn't use the sport shift, so I'd just like to bypass it.
            All the sport mode does, is raise the shift point by a few hundred rpms at partial throttle, which in my experience is useful for around town, hilly areas and when its raining outside (engine braking). With the 92/93 tcu, the sport light will always be on when in D4,(P, R, D3, 2,1) it will be off. From my understanding/observations the 92/93 tcu is a comprimise between the 90/91 regular and sport mode partial throttle shift points.
              is she throwing any tcu codes or is the switch itself shorted?
              i have a 91 accord tcu if you want it.
              Retro!
              Hater
                Her sport light is staying on. When it's on, if she takes off from any gear other than d1 or d2 it's a turd, takes forever to get up to speed, and it kills her gas mileage.
                I was going to check the code, but, I can't find the blue service plug anywhere, aside from climbing up under the dash, I've looked everywhere, it's not there.
                  Its the tcu for sure man, you only have 2 gears, 2nd and 4th, thats why it takes forever to get up to speed, and manually shifting through the gears doesn't do squat. its called limp mode. Replace the tcu, and you'll be golden, it only takes about 10-15 minutes to do, rip up the carpet, unbolt the ecu/tcu from the chassis, remove the bolts/screws holding down the tcu, and swap in the new one, and reverse the procedure. Its also a good idea to plug in new the tcu without bolting everything down just to make sure its the problem, and that the replacement tcu isn't burned out either.
                    Yeah, I figured out it was the tcu, I pulled the backup fuse, started the car, the sport light wasn't on, took it for a spin, it shifted smoother than it'd ever shifted, accelerated great. I was just wondering if I could use a tcu from a 9293 Accord
